drivers for Knauer Azura P 6.1L
Hi
I am trying to control an HPLC pump (Knauer Azura 6.1L) and I was ondering if someone has some drivers or any hints about this (the manufacturer does not help). I have managed to give some commands but the behaviour is a bit erratic (I found drivers for some other pumps for the same manufacturer, but they are not completely compatible).
Thanks for any pointers,
Regards
N
(2,746 Views)
Looking through the documentation of the device support in KNAUER CDS
It seems like the only drivers they have for LabVIEW are:
"LabView (National Instruments): Driver for AZURA Pumps P 2.1S / P 4.1S, Smartline 100, BlueShadow Pumps 10P / 20P"
Unfortuantley I couldn't find any drivers/examples specifically for your device. There is a Micro Pump Driver but this only supports:
Shezan.NABIEL
(2,670 Views)
Hi
Yes, I found these drivers on the NI website... but not the 6.1 which seems to be different. By using the MicroPump Driver I can connect to the 6.1 in TCPIP  port 10001 but the communication is a bit different : there is a header (in big endian) with 4 bytes then some ASCII afterwards that I can understand... I did not purchase this pump, I advise my colleagues to never buy a device that they can not control themselves.
Regards
(2,662 Views)
