ds motors
hello
I need help generate a PWM signal procession, and the procession to take the switch, which will include the DS engine and so he changed the mean voltage.
Thank you,
(2,969 Views)
Need more info.
What is a "ds motor"?
What switch are you talking about?
Who is "he"?
What mean voltage are you talking about?
(2,962 Views)
The idea is to make the code in LabVIEW, which would generate a PWM signal, which is meant to put the management of electromotor direct current-DC motors. This PWM digital signal, which should be such frequencies. 5kHz, should lead to a switch, which will include the motor and send him a PWM signal.
I'm sorry but I do not speak English, I'll do my best to explain it to you.
Thanks for your help
(2,956 Views)
Look for Square Waveform.VI in the Signal Generation palette.  It creates a waveform and lets you set sampling rate, frequencey, duty cylce % .....
(2,950 Views)
Hi Georgije!
What hardware would you like to use to control the motor with the PWM?
There are a lot of examples on NI Community about PWM generation, but it would be good to know the HW you will use.
Here are some:
https://forums.ni.com/t5/Example-Code/Triangle-Wave-Generated-PWM/ta-p/3508230
https://forums.ni.com/t5/Example-Code/PWM-Servo-Control-with-DAQ/ta-p/3521537
https://forums.ni.com/t5/LabVIEW-Interface-for-Arduino/Basic-DC-Motor-with-PWM-CCW-CW/ta-p/3500112
https://forums.ni.com/t5/Example-Code/Counter-Output-PWM-with-Dynamic-Duty-Cycle-Updates-in-DAQmx/ta...
Using this example below, you can create your own solution, that uses just digital lines: https://forums.ni.com/t5/Example-Code/Pulse-Width-Modulation-PWM-IP-Core-for-LabVIEW-FPGA/ta-p/39961...
BR,
CLA, CLED
(2,921 Views)
