11-28-2006 03:45 AM
12-04-2006 09:44 AM
12-05-2006 12:03 AM
I reproduced this error every time on 2 different machine, win2000 and winXP.
Also, I could not install lv 820 on win2000 with sp2, this i do not see in operating system requirements.
cosmin
12-08-2006
01:59 PM
- last edited on
06-17-2026
09:24 AM
by
Content Cleaner
Cosmin:
Thank you very much for your response, here are some suggestions/answers for your questions:
1. I created a library with an OPC server using LabVIEW DSC 8.2 and I then deployed it. After renaming and restarting my computer, I re-deployed my library and everything still worked fine. I am curious as to what you did differently to obtain that error.
2. I would suggest you to see if you can use "Server Explorer" to communicate with your OPC server on the client pc that is running Windows XP and let me know what you find.
3. Regarding not being able to install LabVIEW on a computer with Win 2000 and sp2, Page 3 of the LabVIEW Release Notes mentions that to use LabVIEW with Windows 2000, you must have service pack 3 or later installed.
I hope this helps and please let me know what I need to do to reproduce your issue.
Best Regards,
Rudi N.
12-08-2006 03:14 PM
This is a bit old, since we converted on win2000sp4 for all computers, but I could not connect from 2000 to xp even with server explorer.
You did exactly the same things as me regarding the library and opc client, but i reproduced that error every time, on 2 computers, one with win2000sp4 and the other with winXP.
cosmin
12-12-2006 08:24 AM
12-14-2006
01:52 PM
- last edited on
06-17-2026
09:24 AM
by
Content Cleaner
cosmin:
I hope all is well. I would suggest that you download and install the DSC patch that is posted on our website. I have not been able to reproduce this issue and it may be because I have already installed the DSC patch on my computer.
I hope this helps,
Rudi N.
