dsc Error after install
Hi
I created the project with DSC (LV 2010).
Then I created the Installer.
After I Installed this project on another PC (Win XP) without error.
And when I run my project on another PC I have the ERROR.
I added the Error.
Where is my Error?
Regards
Iskander
(3,904 Views)
Hello Iskander,
This issue may be occurring due to DSC Runtime licensing, in order to run DSC applications on multiple computers you need to have multiple runtime licenses for the DSC Module. To get a better understanding of your issue could you please provide some more information:
Please translate and post the entire error message.
Do both computers that you are using have similar configurations, including operating system?
I have included several links that provide more detailed information about DSC applications. Please take a look at this documentation as a reference for your current application. Hope this helps!
Unable to Locate the LabVIEW Run-Time Engine When Deploying an Application with DSC
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MECSA2&l=en-US
Building a LabVIEW DSC Executable Without the DSC Run-Time System
http://digital.ni.com/public.nsf/allkb/9808031DD3D4C982C1256C4100724ACB?OpenDocument
Deploying a LabVIEW DSC Application with the DSC Run-Time System
http://www.ni.com/white-paper/4124/en
Building Applications Created with the LabVIEW DSC Module
https://www.ni.com/en/support/documentation/supplemental/06/archived--building-applications-created-...
Paul-B
(3,890 Views)
Hi Paul-B
Thanks for the answer.
Excuse me for my silence.
I try to install the "Installer" on a new PC (Win XP)
I installed the DSC RunTime the same version on the new PC.
But the problem is stay.
I installed the "Installer" without Error.
This Error I see when I run the my program on the new PC after installed.
The translate Error:"A problem has occurred in the program initialization dynamic-link library (DLL)"
Best Regards
Iskander.
(3,865 Views)
Hi
I want to add.
After this error I see the next message about error
Respect
(3,861 Views)
