dsc I don't see the Alarms
Hi
I created the SVE.
How can I write value to the SVE with "Write Trace" and then watch the Alarms with "Read Alarms.vi " ?
Regards
Iskander
(2,621 Views)
Hi all
I use in my VI  Shared Variable.
May I Inserts a data break into Shared Variable node ?
Regards
Iskander
(2,607 Views)
Hi, If you need more reference regarding the VIs you mentioned, consider checking the "Database Direct Write Demo.lvproj" & "DSC Alarms Demo.lvproj" at the NI Example Finder.
Alejandro C. | National Instruments
(2,591 Views)
Hi
I solved my problem
Regards
Iskander
(2,565 Views)
