dsc error from "Read Trace"
Hi
I created two projects: server and client.
I used the DSC .
Server and Client are on two PC.
Server received the data and then log its in Citadel.
Client read the date from Citadel.
I used Read Alarms and Read Trace.
The Read Alarms is working without errors but Read Trace has Errors.
What do I do?
The Example is added.
Respect
Iskander.
(2,696 Views)
Hi Iskander,
What are the errors you're receiving?  Could you add some screen shots of them?  Thanks!
Best,
Jeff S.
(2,683 Views)
Hi Jeff S.
I want receive the data on local network from Citadel.
The "Read Alarms" receive the data on local network.
But "Read Trace " don't  receive the data on local network.
The "Read Trace " receive the data from localhost only.
Regards
Iskader
(2,676 Views)
Hi Iskander,
What does the help window say when you hold your mouse over the broken wire?  What is the broken wire along the bottom of the screen?
Best,
Jeff S.
(2,657 Views)
Hi Jeff S.
I noticed that the Read Trace don't work on Local Network.
If I set "localhost" instead of "UzlovOI-PC" - all are working.
"UzlovOI-PC" is name remote PC.
Regards
Iskander
(2,652 Views)
Hi all
Help me.
Regards
Iskander
(2,642 Views)
