dsc problem to convert string to SVE
Hi all
I want to convert the string to SVE.
If I use the computer_name: "localhost" all are working.
If I use the computer_name IP my computer : "192.168.0.54" the "ararms out" is empty.
Why?
Best regards
Iskander.
Message 1 of 10
(3,843 Views)
Hi Iskander,
Localhost = 127.0.0.1, not the IP of your computer which is why you are seeing this discrepancy.
DylanC
Message 2 of 10
(3,817 Views)
Hi DylanC
Thanks.
My PC is on a Local Network. And it has the IP 192.168.0.54.
If I write the name my PC I can see the SVE.
If I write the IP=192.168.0.54 instead of a name PC I don't see the SVE.
Regards.
Iskander
Message 3 of 10
(3,807 Views)
Hi Iskander,
Are you able to ping that IP using the command prompt? If you open NI Distributed System Manager and right click My Systems then Add System and use the IP address for the name does it show the same processes as the localhost?
DylanC
Message 4 of 10
(3,803 Views)
       Try turning off your firewall.
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 5 of 10
(3,801 Views)
Hi all
Dear Luis A. Mata C.
I havn't firewall.
Dear DylanC I did how You write.
I see the same processes in "comp" and in "192.168.0.54" and in localhost in NI Distributed System Manager.
Regards
Iskander
Message 6 of 10
(3,792 Views)
Hi Iskander,
I was able to verify this occurs on 2011 SP1. I am going to do some more tests and will update this thread but for now you can use the computer name as a workaround.
DylanC
Message 7 of 10
(3,781 Views)
Hi DylanC
I noticed that the "Read Trace" don't work on Local Network.
Regards.
Iskander.
Message 8 of 10
(3,763 Views)
Hi Iskander,
       Can you save the code for previous version (2009)? i wanna see it
Best Regards,
Luis A. Mata C.
Ing. Electrónico
BBM Pin: 2B83E99A
Thanks: Kudos
Message 9 of 10
(3,758 Views)
Hi Luis A. Mata C.
Version 2009
Regards
Iskander
Message 10 of 10
(3,751 Views)
