dsc why the data lost after two days?
hi:
I have found some question about DSC module like the picture you see ,there are two lines. ONE is white ,the other is blue.The white one has lost at some place,but the blue one was continuous.
As I know,the computer was crashed at August 25,but the data loss occurred in August 23.It's a long time.So can anybody tell me why it happened.
(3,225 Views)
What is the data? What is displaying the data (graph or chart)? What does your code look like? Why did you post a 4M image to the forum?
NaN in the data will appear as gaps in plots.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,180 Views)
Also, if you are using timestamps from different sources for different channels, you might see gaps as different time sources will most likely (99.9999999% chance) drift to one another. So depending on how often time is "synchronized", the gaps will get different lengths.
Norbert
Norbert
Expert: Geometry
(3,167 Views)
You mean if Igive you the data,you will tell the reason?
(3,134 Views)
(3,134 Views)
No, if you answer the questions you were asked, we will help YOU find the problem. Seeing the datafile is one part, but only one part.
Mike...
LabVIEW Champion
(3,112 Views)
