dstp Hlp pls
Hi
I'm using dstp to read a file and write it to a socket which is read and saved in a file by the client vi on another computer on the LAN .The problem is that sometimes the file is transfered quikly while at other times it takes a long time(or even isn't transfered at all).
How can I solve the problem?
I've left the type input on the data socket read function open since the file type isn't specified.Can this be the cause of the problem?
(2,597 Views)
(2,597 Views)
(2,597 Views)
