dstp not synchron
Hi
I made a vi to transfer sound over the LAN using a dstp connection.If I run the 2 vis on 2 different computers on the LAN simultanously every thing goes fine.But if one is run seconds later after the other the vi won't work(nothing is rcved on one of them or both).
It seems as if the 2 vis couldnt connect & synchronize themself.Should I do any judgement on the error output?
Any comments would be helpful.
I must appreciate your attention in advance
Message 1 of 1
(2,507 Views)
