dt 9834
I am trying to get a dt 9834 to work with labview for data analysis.  I ran the example that came with the data translation board but I cannot get the rates required by the test.  I know this is not a dt website but any help would be appreciated.  I need 50k samples per second over 11 channels on data in.  Any ideas on how to speed up the acq speed.
(2,887 Views)
   DT 9834 has throughput of 500k Samples/s, that means for 11 channels you can't exceed the data rate of 45.45kS/s. You can get higher data rates using less number of channels or using an additional module.
Kudos are (always) welcome for the good post. 🙂
(2,885 Views)
That's what I was trying to tell the engineer!!!!!!!!!!!!!Thank you for the response now they should believe me!!!!!!!!!!
(2,877 Views)
