dual monitor setting on PXI 8108
there is only one DVI port in PXI8108, how can I set up dual monitors?
Best,
Sam
(2,555 Views)
Hi samybae,
You should be able to use dual monitors because the controller uses DVI-I (single link) connectors. This allows you to break the signal out to a DVI as well as VGA connector using a splitter.
Rasheel
(2,530 Views)
