dykstras shortest path
I am trying to take an array of XY clusters and cerate the shortest path through the points, I remember using dykstras back in grad school for something similar.  Has anyone implemented such an algorithm in labview?
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,340 Views)
There is actually an example (in LV7.1) called "shortest paths.vi" that uses the Bellman priciple.  That might get you started.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,321 Views)
Thanks I will look it over.
Paul
Paul Falkenstein
(3,267 Views)
I believe A* is probably the most efficient pathfinding algorithm.  I started to implement one and ended up with a depth-first algorithm.  However, the building blocks can be used for A* as well.  If you are interested, I can dig it up and post it.
(3,244 Views)
