dynamic IP address of DSL router
Hello all,
Is there a way to identify the dynamic IP address of the DSL router? I have a Windows XP desktop that is connected to the internet via DSL. My PC is running LabView 7.0 to acquire data over the LAN using TCP/IP Vis. I want to publish the data over the internet so that I can view the data over the browser. I am using the embedded webserver already built in LabView. How do I figure out the IP address of the router so that I can go to the browser and type in http://IP Address/Program.htm to view the live data?
Any help is appreciated.
Thanks in advance
(2,975 Views)
If your router is running NAT, you can get the public IP by connecting to special IP detection pages such as on broadbandreports using a PC behind the router.
How often does your public IP change? I would recommend to subscribe to a free dynDNS service such as DynDNS.org Once registered, dns information is updated whenever your public IP changes. From then on, you can reach your public IP using e.g. http://kmoorthy.dyndns.org, or whatever you have chosen.
Some routers (e.g. ZyXEL and others) even incorporate a DynDNS.org client so the router takes care of registering the WAN IP change. If not, you need to run a client on your PC that performs this du
ty. Make sure to select something that correctly works across NAT. It is not useful to register your local private address. 😉
Also don't forget to forward any ports that you need on the router. What router model do you have?
(2,975 Views)
Thanks Altenbach. Your answer helped.
(2,975 Views)
