dynamic cluster in subvi connector pane
I would like to write a subvi that takes in a dynamic cluster, accesses its controls[ ] property and acts on the results.  I don't know if this can be done, or atleast have not thought of a viable option.  If anyone has any ideas I would like to hear them.  Let me know if I have not defined my problem well enough.
(3,371 Views)
This Nugget  is probably not what you are asking.
Guessing at what you want have you concidered polymorphic that will adapt to the data type or LVOOP that will call the VI that is appropriate for your data type.
The Polymorphics determine the sub-VI called at edit time.
LVOOP determines the sub-VI at run-time.
Just throughing out ideas.
Ben
(3,364 Views)
Accepted by topic author jon_mcbee
This is possible, make a 'Variant' type connector.
With the OpenG LVData toolset you can get all the info you need.
Ton
My LabVIEW Ideas
(3,359 Views)
Ben,
I have considered polymorphic, but I want the subVI to be robust enough to handle any cluster with any number of and type of control inside it.  I dont know much about LVOOP but I am guessing that it will have a similar limitation as to the polymorphic route.  I was trying to figure out a way to do it with the variant data type but did not come up with anything clever.
(3,357 Views)
Thank you for the idea TonP.  I thought that the variant data type may bear fruit.  I will have a look and see what I can put together.
(3,356 Views)
Wow, that OpenG toolset is great!  Thank  you for pointing me in that direction!
(3,332 Views)
Here is the result of everyone's help.  This VI will take in a variant data type (to handle the dyamic cluster) and will return the control names and datatypes that make up that cluster.
Message Edited by jmcbee on 02-24-2009 09:57 AM
(3,301 Views)
