dynamic data to bit stream
Hi guys. I am trying to make a VI which modulates a dynamic data (like sound) using digital modulation like FSK or PSK. But FSK block accepts bit stream. I want to know how do I convert dynamic data like sound to a bit stream, which block or VI should I use to do that.
(3,538 Views)
Does the FSK block expect an array of U8s? Or is it an array of Booleans? In general, to convert from the evil dynamic data you would use Convert From Dynamic Data.
(3,527 Views)
Hi Smercurio, FSK block expects bit stream. it doesn't accept U8 or array or boolean.
(3,511 Views)
Are you referring to the MT Modulate FSK VI? According to the documentation, that VI acceps an array of I8 values as the "bit stream".
(3,503 Views)
Let me try this...
(3,490 Views)
