dynamic formulation
I am getting a list of channel information from MySQL table via LabView. The
last field is the scalling function fro example
Data=8*(OutputVolt-21451)/78415
The field that I am talking about is the right side of the equation. It
comes as a string. What I want to do is to use this function in a dynamic
formula VI. So I will input
1) The Volt
2) The formula
And get the scaled data..
Any idea?
TIA
(2,794 Views)
In all except the base version of LabVIEW, you've got the Eval Formula Node (Analyze>Mathematics>Formula palette) and the functions under the Analyze>Mathematics>Formula>Advanced Forumla Parsing palette. The formulas have to adhere to a certain syntax or you modify the strings match the acceptable syntax in LabVIEW but I think these are what you're looking for.
(2,794 Views)
