dynamic scales and custom gauges
I have some simple code for a gauge I need that changes the Min & Max Scales based on the current input value.  For example, my Min/Max is 0 to 180, but when my input exceeds a value of 70, I want my Min/Max to be 60 to 180.  However, I want to use a custom gauge (pictures) so I need the picture of my gauge to flip from one showing 0/180 Min/Max to one showing 60/180 Min/Max.  I am not sure how to do that.  Any ideas?  Thanks in advance.
(2,717 Views)
Accepted by topic author jcgrcya
My initial suggestion would be to make the gauge housing transparent and put it on top of a picture ring control.  Use the picture ring to toggle the picture and use the gauge to give you the needle/scale/etc.
If you need to reuse it and want to keep the block diagram clean then this might be a good time to wrap it up as an XControl.
~Simon
(2,713 Views)
Simon,
Thanks.  Works like a charm.
JC
(2,706 Views)
