dynamic terminals
By the way, just in case you don't know them, the OpenG data tools already do the recursive parsing of variants, so at least that part is mostly handled for you.
___________________
Try to take over the world!
Message 11 of 18
(2,022 Views)
One problem with the variant, I actually was using the lables of the controls as tags in my application.  Varant only pass the data, I might be back to the references.  I need a generic terminal which will adapt to the input wire as a strict type, probably cant do this without some scripting method.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 12 of 18
(2,001 Views)
The OpenG data tools allow you to get the data name, which is the label for the control in your case. See here for an example (and follow the link at that post)
___________________
Message 13 of 18
(1,995 Views)
Great I will check this out.  Thanks
Paul
Paul Falkenstein
Message 14 of 18
(1,992 Views)
I also know from personal experience that the variant retains the name.  Check out my nugget which uses exactly this aspect of variant data.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 15 of 18
(1,979 Views)
A new option: xml.
You could use the Flatten to xml String VI, that takes anything and passes data, data structure and names.
Felix
Message 16 of 18
(1,974 Views)
Thanks the variant and openg tool kit are working very well.  I am able to do everything that I want with this.
Paul
Paul Falkenstein
Message 17 of 18
(1,947 Views)
MGI just released a new solution which essentially does the same thing as the OpenG solution, but is supposed to work faster and uses vi.lib VIs for the type parsing, but I haven't checked it out, because it's 8.x only.
___________________
Message 18 of 18
(1,939 Views)
