dynamically change waveform's y scale properties
I have 8 stacked plots on a waveform. I would like to dynamically change the y scale name and min/max values for each plot (the user selects these).
Is it possible? Changing any of these properties only seem to effect the first plot. I have also tried setting Active Plot dynamically but it only effects the plot related properties (eg: Plot name).
(2,625 Views)
Hello abdel2,
Please post the version of LabVIEW you are using as well as a screenshot of what you would like to achieve on the Front Panel.  Please also attach your VI for review and suggestions.
George T.
Senior Applications Engineer
National Instruments UK and Ireland
(2,606 Views)
