dynamically loading vi lib vi error 1003
I cannot dynamically load a vi that includes a vi from the vi lib.
See example.
How to test:
  •          Unpack the zip file.
  •          Open the project
  •          Set the path in testloading.vi to the path of file to load
  •          Make current values default
  •          Build executable.
  •          Run executable.
  •          A dialog appears and you need to point to the file in vi lib.
If you point to the file in the vi lib, the vi is not runnable because the file still has a question mark.
(3,260 Views)
Tested on my machine with labview version 2013 service pack 1 fix 2. Also not working, same result
(3,248 Views)
Hi Jonvo.
I believe I have seen this before. I made a rather long description of what is causing this in another forum post. Please have a look:
Missing vi.lib files in Run-Time LabVIEW 2012
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(3,195 Views)
Thanks for the clarification!
(3,169 Views)
