dynamically randomize position of ring pictures
I wanted to randomize position of ring pictures. I succeed. I wanted also, when a user clicks on any picture, the picture make invisible and repeat this until only one picture remains.
Now, What I want to do is to randomize position for each trial. Here, in the code I send you when a user clicks on one picture, the position of remained pictures doesn't randomize after. How can I do?
Then, another problem, if it is not too hard for you, I want the VI stops if the user doesn't click on any figure within 5 seconds for example (I used elapsed time Vi but it doesn't work).
Thanks in advance.
Message 1 of 18
(3,552 Views)
Hi Nousome,
You may want to take a look a the example I have linked to in post #4 of this thread.
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=14&jump=true
It shows you how to move a random number of objects around on a picture control and makes them each disappear under the appropriate conditions.
If you adapt that example with a detection of where a user clicks on the pciture control, it sounds like your project is half done!
If you use this approach, please post an example of how you did it and I will add it to the collection.
"Trying to teach you how to fish"
Ben
Message 2 of 18
(3,552 Views)
Thanks I will look at this.
Message 3 of 18
(3,539 Views)
Sorry Ben, I an a beginner and I don't understand very well your code, it is a little more complicated for me. Could you look at the Vi I sent, please?
Message 4 of 18
(3,528 Views)
Message 5 of 18
(3,510 Views)
Hi Nousome
randomizing a picture position is different from having different views of the picture control.
look at my other example, I'm not usisng the picture position at all and still show all possibilities.
You only need two picture rings and eventually move them around.
Stop using so many controls and indicators.
greetings from the Netherlands
Message 6 of 18
(3,507 Views)
Of course, sorry I express badly what I did. I didn't change the positions of rings but change only presentation of picture into the ring (which contains all posibilities). I display 4 rings because I want them to be displayed all simultaneously.
My problem is to activate random number after each time the subject clicks on one picture. Here, the random number is active only at the beginning, I don't succed to reiterate it despite trials to use in a while loop or for loop.
Message 7 of 18
(3,498 Views)
is this what you were trying to do.
tell me if you need anything else
Message 8 of 18
(3,490 Views)
thanks a lot, it works almost like I want. The only problem I discover when I simulate the vi is when the subject clicks on a rectangle, for example, it is the rectangle I want to eliminate and not only the ring picture. The random cannot reactualize the number that it has to select.  I don' think at that before.
Message 9 of 18
(3,486 Views)
So maybe the solutions is to randomize position of pictures (which contain each only one shape). But is it possible to randomize position of a control?
Message 10 of 18
(3,474 Views)
