dynamically resizing stacked plots depending on visibility of scale
is there a way to change plot width in a chart with stacked plots, depending on visibility of scales and number of digits of scales _and_ without resizing width of the chart when all scales are invisible?
The problem: when all scales are invisible and the number of digits increases, the chart's width decreases and the scales move a little to the left.
Thanks a lot in advance.
Cheers,
Martin
(2,508 Views)
Hello Martin,
Could you please attach some sample code of your question. Also, if would be really helpful if you could document the front panel of the code with what to do in order to see the problem you are seeing with the chart's width decreasing.
Thanks.
(2,508 Views)
