e 5071c 3 traces
Hi, i want to record S11, S21, and S31 on a waveform graph for 48 hours to monitor drift.
The network is an E5071C, the software will be Labview.
On the drivers downloaded i can only have one trace.
Any help how to build this v.i or if anyone has one?
Thank you for your help.
Yalt
(2,474 Views)
Good Afternoon yalt,
From where did you download the driver?  What driver is it?
If the driver only allows 1 trace, maybe you can implement it multiple times or iterate through a loop.
The solution will depend on the driver being used, the data which is being collected, at what rate that data is being collected, and what your application requires.
(2,458 Views)
