e4440a integrated power measurement
I'm attempting to extract an integrated power measurement from an E4440a but have run into a road block (see attached file for Labview config).  The E4440A is setting up properly in the intergrated power measurement mode and the signal is aquired but the power is not displayed.  I'm not sure if I need more sweeps and if so I not sure how to do this.
Mark
(2,484 Views)
Hi mad4,
I am not familiar with your instrument, but have you tried using the LabVIEW driver from the Instrument Driver Network?  It can be found here.  These will have everything set up for you already.  Try this out and see if you are seeing the same behavior.  Best of luck and have a great day!
Chris R.
(2,441 Views)
