12-17-2009 12:13 PM
Is there an easy way to transfer development environment settings?
I just installed to another computer and it drives me nuts everytime the function pallet is always different and the block diagram grid is not on...
Are the user settings stored in an INI I can just dopy over?
Solved! Go to Solution.
12-17-2009 12:33 PM
Yes sir!
program Files\Naiotnal Instruments\LabVIEW2009\LabVIEW.ini
Ben
12-17-2009 12:35 PM
The .ini file for LabVIEW is most likely located at C:\Program Files\National Instruments\LabVIEW <version>\LabVIEW.ini
You can just copy the .ini from the computer whose settings you like into the LabVIEW folder on the other computer (overwriting the default .ini). You will need to restart LabVIEW to see the changes.
-RW
12-17-2009 12:39 PM
