edge detection with mouse event
I tried to adapt the edge detection example to my program but the while loop freezes the screen. I have a 3D image array and i can choose which image i want to see thanks to an event structure. I would like to be able now to work on the image.
I wanted to use one of the ROI tools (drawline) but i can't handle different types of events : a changed value to choose the image, and a draw event on the image which doesn't need an event structure but a while loop checking if there is a change every 5 ms.
I think that i should deal with the draw event with an event structure but it means I lose all the advantages of the ROI tools...
I attched my Vi (it is not working, i must change the frame number to get information about the profile...).
Please help...i am really stuck!
(3,008 Views)
Is it possible for you to attach the real VI not just the print screen ?
(2,981 Views)
