edit 3d scatter
does anyone know if it's possible to edit a 3d scatter? I want to be able to move the projection palette somewhere else, and couldn't find how. Thanks in advance
Gabriel
(3,834 Views)
Hi Gabi11,
do you want to move the palette or hide it? If you want to hide this palette, you can right click the plot >> Visible items >> and unmark Projection Palette. Let me know if this is what you are looking for.
Have a nice day!
Jesús
(3,790 Views)
There is another thing you can try:
1.- You can hide the projection palette the way I mention on my previous post.
2.- Go to Block Diagram and right click 3D Scatter indicator >> Create >> Property node and place it on the Block Diagram.
It is possible that one of the listed properties allows you to reach the same functionality as pushing the projection palette buttons on front panel, but I was not able to figure out which property. Maybe you are more lucky than me.
If you try any single property on block diagram and you cannot replicate this behavior, I am afraid that this is not possible.
Good luck!
Jesús
(3,784 Views)
Hi Jesús,
thanks for your answer, but I actually want to move it, not hide it (the waveform charts or other 2d plots allow me to move the different objects they have, but this 3d scatter not).
If someone tells me that it is impossible to move, I would hide it manually (no problem there) but I would like to be able to change the projection view with some property node. I looked and there is none that I could fine that changes the view.
Gabriel
(3,780 Views)
Accepted by topic author Gabi11
Hi Gabi11,
in that case, I am afraid that it is not possible to modify it anyway. Sorry.
Have a nice day!
Jesús
(3,772 Views)
