edit cluster
Is there any possibility to edit programatically the values of a list box, which is inside of a cluster?
In the example attached, how to add, when needed, new temperature or voltage values?
(3,339 Views)
Right click the list box and select Create property node, select property Item Names witch is an array of strings from where you can read the actual values and to where you can add new ones.
Check annex,
Hope this helps,
Paulo
(3,335 Views)
Quick and right! I was taking a too complicated way...
Thanx!
(3,329 Views)
You could also extract the reference, which is assigned to a property-node. There you can set the values.
Just see the attachment.
Hope this helps
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,328 Views)
Yes, this second option will be more helpful to handle data between subVI´s, which is also interesting for my aplication.
Thanks to both
(3,312 Views)
