edit the [LDF] database file
I'm searching a way that can edit the database file *.ldf, cause some customers wouldn't put the Signal_endcoding_types in the ldf file. I need a way to save the "encoding" in the file with labview UI. I've found some old APIs for ldf file, but I've tried out, it seems like, that they only works on old versions. The version of my ldf file is LIN_protocol_version = "2.0"; LIN_language_version = "2.1"; does any one could tell me if there's any way that can realise my target.
Thank you in advance
best regards,
Melo
(6,579 Views)
What DBMS? Can you explain your problems a bit more?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(6,536 Views)
Hi Mikeporter,
I mean the specification file *.ldf of LIN communication.
best regards
Melo
(6,452 Views)
Accepted by topic author Krapfen
Do you actually want to edit the LDF file?  Because if so there is nothing NI currently provides that will work for you.  If you want to use the LDF in XNet, and you want to modify settings imported from the LDF then you can use the XNet API to achive this.  When you use XNet you import the LDF (or other database files) and then you can edit the database, but this doesn't edit the LDF.  This edits the database that XNet uses, which was started by importing the LDF.
Recently there have been updates to XNet that allow exporting a database but I believe they only support exporting to a CAN database.  So with CAN you can import a DBC into XNet, edit it using the database editing tools, then export it back to a DBC that should have the edits you made.
(6,438 Views)
Hi Hooovahh,
thank you. it makes me much more clear.
(6,430 Views)
