I tried this and was able to reproduce your problem and fix it.What I did was,
1. Make sure that the delimiter setting was set to tab inside the read vi.
2. Made sure my decimal point setting was correct.
3. made sure that when saving the file, when excel asked to keep the settings I said yes and saved as a .txt file. do not save it as a .xls, you will not be able to read it correctly (At least i could not get it to) You could also save it as a .csv if you want.
4. Made sure my convert from dynamic data was set to 1darray of scalar automatic.
after all these changes I was able to read the file correctly after editing with excel. I think the biggest thing though was the way I saved the file.
Hope this helps
Joe
Joe.
"NOTHING IS EVER EASY"
