editing single key value within ini file
@billko wrote:
@JÞB wrote:
Guys.... sometimes you need to pay attention to the little things.
@lamar, when you edited your ini file with notepad you inadvertently changed the file name from
Test.ini. to
Test.ini.txt
So, test.ini never changed and the code still ran with the original settings.
Oh, well.  Everyone got a lesson in how to use the config VIs and some advice on LV best practices.  😄
It was good advice!  AND BONUS,  when the OP applied said advice, notepad stopped changing the file extension solving the problem.
Message 11 of 11
(578 Views)
