eerror 56
Error 56 occurred at TCP Wait On Listener in TCP Listen.vi:1->TCP _IP.vi
Possible reason(s):
LabVIEW:  The network operation exceeded the user-specified or system time limit.
Prashant Soni
LabVIEW Engineer
(3,347 Views)
Hi Prashant Soni,
what timeout have you connected? If you want to wait til a connection, then you have to use "-1".
Mike
(3,342 Views)
Dear Prashant Soni,
thank you so much for your post on our webforum. Can you please explain more regarding the issue you see; are you trying an example and facing this problem (which example)? If not please try with an example, and if it is related to your own VI, please make a small sample which we can review. Is this problem between two PC's? When do you see this problem?
One important thing to keep in mind is your safety software like firewall; a firewall can block the port you try to communicate with.
Martijn S
NI Netherlands
(3,340 Views)
Hi prashant.
You'll have to give a little more detail. Maybe post a snippet of your code or something.
Try this link too
Jevon
(3,339 Views)
See this
AND
this
(3,338 Views)
