elapsed time since boolean true
Can you tell me how the boolean for the range and coerce vi works. I am confused as to when it should be displaying true/false.
Message 11 of 12
(435 Views)
When playing the vi, the boolean is originally off when the slider is below 160 and the status displays "False since...". It does not light up until the slider reaches 160. The status then becomes "TRUE since..." with the boolean lighting up briefly. The status does not return back to true no matter what value the slider is. I don't see how this corresponds to the ranges specified by the range and coerce. Also, is it possible that the boolean will be continuously on while the elements are in the range specified and then off when they are not?
Message 12 of 12
(431 Views)
