elemental I/O with ADSP-BF527
Good morning,
I am using the LabVIEW Embedded module for blackfin processors, and I want to use the Elemental I/O for that target. The problem encountered is that this target does not support the Elemental I/O. So how can I use the pins of that target (PWM, analog and digital pins).
Thank you.
(2,798 Views)
Accepted by topic author ahmed_uqat
Hey,
Yeah unfortunately your device does not support elemental I/O according to How Do I Access All Elemental I/O on my Blackfin Microprocessor. Here are two other ways to "communicate" with your device: Blackfin Discussion Forum using Inline C Node and LabVIEW Help for Blackfin Module. These are two ways that you can get and send data to your device. There is also this page that has VIs specific to your device.
David
(2,749 Views)
Hey,
I have found the bloc I/O in the Blackfin module. I try to generate à PWM signal on the pinout. I use the Timer I/O and I want to configure the two registers of the card PORTG_MUX (Multiplexer) and PORTG_FER (Function enable register). I have not found the bloc that writes to those registers.
So does this module for Blackfin have this feature?
Thank's
(2,733 Views)
