elpased time
elapsed time :
i have to get transmitrates, frequency, allocated time for hash and signature, # of retransmissions
i found
Transmitrates    128bits
frequency           628 HZ
i got (  x-y ) = 102-105msec i think this is for hash and signature
can any one tell me how to calculate # of retransmission
Message 1 of 13
(4,266 Views)
Zero. You VI only runs once and you have no code to even request a resend. Please don't say your are using the run continuous button.
Your  overall time is for the entire VI. I don't see how you can it does not include any of the other functions you have there. Did you run the profiler?
Message 2 of 13
(4,260 Views)
can you tell me how to resend, i dont know exactly how to resend it
Message 3 of 13
(4,256 Views)
To start with, you would need a while loop. I would then recomend state machine instead of that silly sequence structure. In a state that checks the data, set the next state to be either resend or send new. You would keep the last data sent in a shift register.
Message 4 of 13
(4,243 Views)
i dont know much about state machine
Message 5 of 13
(4,228 Views)
For retransmission i ran the vi twice, i got the elapsed time 205msec
Message 6 of 13
(4,192 Views)
Here is a KB on State Machines
http://zone.ni.com/devzone/cda/tut/p/id/3024
Message 7 of 13
(4,165 Views)
Well, it's obviously not the same thing as doing a retransmit but if you want to call it that, that would be up to you. In another post of yours you also say you are using cryptography but of course you aren't encrypting the data at all so I guess your terms are different than mine.
Message 8 of 13
(4,154 Views)
i dont know how to retransmit . what to do for retransmission. Can you explain me
Message 9 of 13
(4,140 Views)
I did explain. In a state machine, you would keep the last packet sent in a shift register and just send that. Going back to the beginning an creating a new signal, converting it to digital, etc. is NOT a retransmit. Because you are not really sending anything anywhere, your retransmit time is going to be next to impossible to actually measure.
Message 10 of 13
(4,080 Views)
