email HELP?
hi i've try to send email with gmail to ymail, but i've some trouble.
please help me
Message 1 of 8
(5,483 Views)
What version of LabVIEW you are using?
Go through all these posts and post if still you need some help.
Message 2 of 8
(5,475 Views)
labview 8.6
Message 3 of 8
(5,473 Views)
Message 4 of 8
(5,452 Views)
muks wrote:
See the attached vi
Works like a charm!
(Too bad I can only give 1 kudos per post)
Patrick Allen: FunctionalityUnlimited.ca
Message 5 of 8
(5,434 Views)
i've download your vi but it's still have same problem.
Message 6 of 8
(5,355 Views)
You will need to provide more information, such as which node is actually generating the error. Run the VI in debug mode with highlighting on. Identify which node is first generating the error. There are some nodes that do not have the error I/O wired. Please make sure to wire the error wires before running the VI.
Message 7 of 8
(5,332 Views)
Please attach your vi that you have wired.
Message 8 of 8
(5,292 Views)
