11-26-2012 11:41 AM
Have confirmed I have a working SMTP connection. Email of recipient is correct. When my vi goes to send the email, I get an error message saying the 'network connection was closed by the peer'. My IT folks are at a loss and so am I.
Ron
11-26-2012 01:05 PM
You haven't provided enough information to help.
What type of server are you connecting to?
What port number are you using to connect to the server?
Does this server require SSL?
Are you trying to include an attachment?
11-26-2012 01:16 PM
Phillip,
Thanks for the reply. As I figured, it was firewall on my IT side. It only took them 6 hours to turn it off!
Ron
11-26-2012 01:22 PM - edited 11-26-2012 01:27 PM
Glad you got it figured out.
FYI there is this example that can be useful when you need to communicate with an external email server (GMail) or need to use Authentication.
https://decibel.ni.com/content/docs/DOC-2401
11-26-2012 01:34 PM
Phillip,
Yes, I had already checked that out. As a result of everything looking fairly straight forward, and also that I had it working earlier last year, it didn't make sense. Once you fingure in IT, everything makes sense!
