embed an application
I am tryinf to run an application (a remote desktop application) in a labview program.
My question is:
Is it possible to embed this remote desktop into a labview box? I do not know if it would be possible by using Active X containers or so.
Thanks in advance
jm
(3,021 Views)
Hi jm,
Good afternoon and I hope your well today.
Thanks for the post!
Have you seen this forum?  Bascially, its not be made easy in labview by design - but if you work at it you could achieve this.
Then using google I found that Remote Desktop ActiveX Control can be downloaded from the microsoft website.
To embedded this into LabVIEW front panel it would seem you could use an ActiveX container. I would consider looking at the Google Earth examples that show how to embed a webpage into LabVIEW front panel.
So to make it clear, you have two steps,
1) Embed the Remote Panels into a webpage (the way I read it)
2) Then use ActiveX to display webpage on labVIEEW front panel
Hope this helps some,
Message Edited by Hillman on 06-17-2009 03:53 PM
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,012 Views)
