embed chm file into a VI
Dear all,
I'm writing a "dummy" configuration editor (easier than xCE) with a tree on the left side and a subpanel on the right side (see cfg.bmp).
Some selection in the tree control opens, on the right pane, subVIs with the a WebBrowser ActiveX control where I display some information (see cgf.bmp) from a html file.
This work fine in the development enviroment, but include alot of html files, with their folder structure for images, is quite tricky in exe.
For this reason I'm looking for an alternative solution based for example on chm files.
Is there a way to show a chm file inside a the WebBrowser ActiveX control?
I've already tried using methods: Navigate and Navigate2 with this url: mk:@MSITStore:C:\WINDOWS\Help\ntshared.chm::/copyright.htm, that works fine into internet explore, but fail inside a VI.
(2,334 Views)
(2,318 Views)
