empty visa resource drop down menu box
After my system is restarted the visa resource drop down menu box is always empty even if I hit refresh unless I start up MAX then close it then the box gets populated again.  This is very inconvenient.  I'm using MAX 4.6.2 with LV 8.6.1 with all the services running.  Is there a way to resolve this issue without manually starting up MAX and then close it after each system reboot?
(2,595 Views)
Hi lavalava,
I tried recreating this issue on my machine and the visa resource box populated as would be expected. The version of MAX that you are using is a few back, I would recommend updating the VISA driver, which will bring the newer version of MAX with it, and then see if you are still experiencing this issue. I have include a link to the driver below.
http://joule.ni.com/nidu/cds/view/p/id/2251/lang/en
Peter W.
(2,567 Views)
