emulate a regulator control systems using LAbVIEW
I trie to emulate a plant but my control is outside pc (inside a micro-controler) please anybody Knows where can I find information about it
(2,766 Views)
I am not sure exactly what the question is but let me see if I can help narrow it down.
Are you asking how to get data into the computer from the controller? Or do you wnat to know what equation to use?
Are you asking if NI has control VIs? If so yes there is a PID toolkit.
If you could give us more information on the question we may be able to help you better. In addition, NI has branch offices all over the world, you may want to send an e-mail to your local office asking for help.
(2,766 Views)
Thanks Evan for you help ....My application is about a emulation.
First) Modelling a plant (using LabVIEW) that way PC inside PC (virtual plant)
Second) Realize the control of the plant ,through a microcontroler outside PC (using a control algorithm)
...so I ask about the way that I can communicate PC (LabVIEW)- Microcontroller (it realize the control-using algorithm) : using DAQ ...or using ISA bus , PCI bus or only serial bus?
please I`m new using labVIEW and I should be very obliged if you send me your advise ,information about that, or tell me where I can find more information about application like this or to recommend literature about that.
Thanks a lot
Leonardo
(2,766 Views)
