enable user to choose pick color from color palette
hello, i have a program that uses the color-matching function. when the program runs, i want to allow the user to choose a color from a color pallete and then this color should be matched
with the colors in images. i use "imaq setup match color pattern" and  "imaq color pattern" functions which use templates  as an input and these templates have to be manually assigned before run.
is there a way to allow the color palette to act as a templete input???
thankyou
(2,656 Views)
Sure,  Put a color box control on the front panel.  It is located in the numeric palette.
(2,633 Views)
