encoder and speed sensor
Accepted by topic author 56456
Have you tried using counter 2 or counter 3 in your second DAQ Assistant function?
You are using the large range 2 counter method in both of your DAQ Assistants, but the 6351 has 4 counters and should be able to read 2 encoders this way. Note that unlike other measurement types, only one counter measurement can be used in a single task. You must therefore create a unique task for each counter operation. Does the error appear using ctr2 or ctr3 for the second task?
Andy C.
Applications Engineering
Message 11 of 14
(1,835 Views)
thnx Andy!! it worked well when I used ctr2 for second Daqassistant.
here are my last questions;
can you tell me how to filter un wanted picks during measurment as shown attached picture? and please guide me how to save and export my measurements.... thnx again Andy.
Message 12 of 14
(1,826 Views)
is there a better filter than median filter for this application?
Message 13 of 14
(1,819 Views)
I'm glad you were able to get your measurements working!
As for your follow-up question, you may have better luck posting a new thread over on our Signal Conditioning forums located here.
Cheers,
Andy C.
Message 14 of 14
(1,801 Views)
