end a queue
I emulated the code for this post: http://zone.ni.com/devzone/cda/epd/p/id/1959, however, the vi is an older version of Labview.
Most importantly, "Not a queue vi", is no longer available at least in version 2009. So how do I end the while loop once the last element is out.
This is the block diagram from the NI site:
While this is my own emulation using version 2009, as you can see, in the while loop there is a function " Not a queue vi", which I can not find in the 2009 version.
I even tried wiring the # of elements in queue from the Get queue status vi to "=0", then wired the output to the stop terminal, but got an error.
(3,435 Views)
Accepted by topic author ade77
Hi ade,
you have to check the error cluster (as you should do anyway in a good program...)! (You picked one of the examples written for LV6 or even older, which should be updated by NI sooner or later...)
When you release the queue it's reference get's invalid. The GetQueueStatus function then gives you an error which you can analyze. End your while loop when an error ("invalid reference") occurs...
(3,431 Views)
