enebled debugging on executable - gives an error with 2016 Runtime
I have   LV 2016 RTE  installed.
On my development PC I made an Exe. with Debugging Option ON.
Unfortunately, this does not work  on the  Deployment machine.
How can I  enable or disable  through a key or swith the Feature so that this  Exe( with debug option) works.
I do not want to make another exe because the Version number  changes and the customer has issues with that.
regards,
Akshay
(2,226 Views)
Hi Akshay,
The debugging option can be configured only in the application builder.
Could you give me the error code, what you receive? Maybe that would give us a clue, what is the issue with your application.
Ambrus
Ambrus
Technical Support Engineer
??It's just business ??
(2,201 Views)
