energy meter after closed labview ???
hello to all
I want to do an energy meter on labview basing on the feedback node with summation
in this case there is no problem increments the counter very well
  labview but just closes the counter resets to zero for this
  I'm looking for a way to memorize the last counter value before switching off the labview and then inject the last value as an initialization
  and thank you
(2,814 Views)
Then you have to write that value to a file and then whenever you start the code read it from the file and add that to the present reading.
(2,810 Views)
Try something like this.
=== Engineer Ambiguously ===
(2,803 Views)
This has been asked many times before. Next time please do a search before asking your question.
Community: Easy saving and loading of control values
(2,796 Views)
And I gave you a similar answer on your french version of this post here.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,792 Views)
