enter data into table row by row
Dear all,
Is there any way to enter data into Table "Row by Row".
Presently, i am sending a 2-D array of string into the tble, but i am getting data for a particular row at a time.
So, it would be really efficient if i enter data into a particular row(1-D array of String) and not the complete table.
Ritesh
(3,210 Views)
Hello Ritesh,
use a local variable of your table indicator to read the old table content and simply append a new row to that array with the Build-Array-Operation. Than update your table with the resulting array.
Depending on you application it might be useful to alternatively use the Insert-Into-Array-Operation.
The key is: first read the old array content, modify it and write it back to the table. I think this is the only possible way.
Thomas
(3,200 Views)
No need for a local. Just use a shift register.
(3,176 Views)
