enum data items dynamically
Hi jabili,
I'm not sure if I understood you correctly. What properties or invoke nodes are you using? You should take a look at the supported methods for PDA and supported properties for PDA links that Eric posted to determine the properties or methods in your VI are supported in LabVIEW PDA. If any of your invoke/properties node is not listed in the above links than it is not supported in LabVIEW PDA.
Stanley Hu
Applications Engineering
http://www.ni.com/support
Message 11 of 11
(1,286 Views)
