enum elements or buttons?
Hi Altenbach,
well, as I said, the VIs perform fine individually. My MainVI is not working. It is a bit complicated, all the Listboxes are populated using SQL queries, and the database has several relational tables. I use a mouse up to do the following: click on the header of a column and sort the column, as well as fit the width size of the column to the largest cell. The values of the list boxes are being processed, just could not capture all the events in one screenshot.
It might not be that easy to find out what is causing the problem without the actual code. But thanks anyway.
Seli6272@D
Message 21 of 22
(601 Views)
Update: I realized what I was not doing: I was not running VIs, just inserting them into the subpanel, so they were just static Multi column listboxes which were inserted and not really running. Tnx for your support.
Seli6272@D
Message 22 of 22
(592 Views)
